DirtyD
Not the throttle cable...lol..that's fine...my bad...the tear is in the clutch cable and the clutch cable bends at a 90
Sent from my EVO 4G using Tapatalk
Then do you think I still need the clutch kit...and if so the entire kit or just the plates with teeth
I only rode it once and didn't ride it hard once I noticed a problem I stayed at 45...
I have the clutch apart and all the plates out...they do have some blueing and a couple of the steel plates are also warped slightly ...do they look bad to you? Ex...my problem
How much oil should have been on these?..they are slick but not dripping....
And if you can see the gunk around the bottom should I clean with clean towels and brake /Carb cleaner?...
I should have new cable and clutch kit Mon/Tues...thanks
New springs, steel plates and friction plates...
Great! She'll be good as new!
I hope so Billy....and it goes to figure the bike is down when here in Indiana we've had 5 days in a row of record highs and still counting 70's and 80's
