- Thread starter
- #81
DirtyD
I'll try that...that's the problem its like the new plates are a hair bigger and covers part of the groove
Sent from my EVO 4G using Tapatalk
Well, I got the clutch all back together and cover back on with new gasket, hooked in the new clutch cable line...and the damn this is so freaking loose...I adjusted the cable at the lever and just after the bend under the tank and its is still so loose....so I went to adjust the free play adjuster on the left side of the bike and that was all the way tight...I'm just irritated now![]()
Its factory..and before put it in I adjusted it to the same as the original
I appreciate all the help...but I broke down and took it to the dealer....1-2wks out....they really actually booked until the 1st of May...but since I install their signs they are gonna squeeze it in somewhere
Dealer called.....to disassemble and reassemble the clutch...replace the wire clip in back of the clutch assembly....drop the oil pan and thoroughly clean screen and all then new synthetic oil and filter.....300 bucks and I'll have it next week....
So a total around $500...damn
Well, I got to pick the bike up today, and rode it home, it was about an hour ride...The bike felt good and upshifted fast and smooth, the downshift felt a little hard, but not bad I guess...
The ended up replacing the wire clip that goes into the back of clutch boss, apparently that broke and came undone on me, so they changed that and some gaskets and drained and cleaned the oil basket and screen and obviosly changed the oil and filter...
All in all, I'm happy, I get to ride a gain...
Thanks to everyone that posted and viewed, especially to Cobalt, YZFriderNY and Stretched!
