FZ1riderNY
Moderator
Well, I'm back from "Bike Night", but not before finishing the pod light mod. Everything was very easy to do and the finished result was fantastic. Thanks to Eric for posting this mod. I'm very happy with the outcome. As for silicone to seal the plug, its not necessary. If you take a razor and slice a tiny bit from each ear on the plug, it locks into the hole very tight and will not pull out unless you really yank on it. The base of the plug makes a perfect seal. Here are the pics of the finished process.......
I used quick connectors for the hook-up rather than splicing and soldering...
Here's the finished hole on the left side of the bike.....
Here's the plug installed securely in the hole......
This was the right side once finished.....
And finally here's the finished product. It really makes the front end look nice..
