Ruggybuggy
For those that have done it. Is it worth the approx. $400 after shipping to get it done? What are the benefits that were noticed? He provides his own map. I'm presently running a JB Pro with the Lar's map.
Yo buggy do you have headers?
DO IT! The bike is much smoother. Shifts smoother, idles better, smoother power band. It runs cooler (which may not be a big point for you way up there). The power difference is immense. There is less engine braking. My mpg hasnt changed much but thats ok to me. I have nothing bad to say about it at all.
Hope this helps,
Matt
Map is f*in rich at small throttle openings... my commute mpg dropped due to that .... I zeroed 0% throttle and leaned out others ... my mpg is back now
Interesting! I am getting better mpg ( if that is what I am trying for) with the new ecu flash and Ivan's map than I got when I was using Jondaddy's map, before the re-flash, and it was really lean.
My cruising rpms are normally at around 5 to 6 grand. The bike is butter- smooth at all rpm's and for some reason loves to test out the new redline.
This mod is worth every penny.
David
Mines going tomorrow. Looking forward to the results.
is it available for us, Europeans?
I'm going to send mine in soon. Also use Pete's suggestion and re-route it to under the seat. I might pull it Sunday night and ship it to Ivan on Monday. Looking forward to all the changes, smoother throttle and custom map. I'm even going to put in the stock flies as he's compensated for that in this flash.
He's done a lot of them already and from all over the world. It's got to be that good.![]()
