- Thread starter
- Admin
- #101
FZ1inTX
Adminstrator
I know what you mean, but then you'd have to get used to riding/driving on the "wrong" side of the road![]()
Not really.... I'm always in the passing lane now.
well, happy to report that I'm able to get Rabeet's custom flushmounts to work in a fashion that I am becoming very accustom to.....
I now have Running lights instead of all the LED's blinking (came that way from the person I purchased, and up until recently, I was Electrically slooooooooooooooooow.
Thanks to some help from va_rider on some residential work, I have started to see the light at the end of the tunnel, and can possibly get it to light up as well.....
I'll post some pictures and also some diagrams that I found and have you's who know all the symbols, give me a quick rundown so I know exactly what it is that I'm looking at...
more to come.....
Reading this thread today made me take a trip to Auto Zone, 1 hour later, done.
Great write up and pictures. I ended up using the pinch quick connectors as well because I'm naturally lazy. :newbie:
edit: had to take a picture
I have been wanting to find an inexpensive way to do this ever since I saw those empty spots that looked like they should have lights there. Thanks for the great write up!
I did find an option for anyone interested. Discount also had some 90* sockets, which I figured may protrude less for a cleaner install. Part #85868
Also considering installing some colored LEDS (red) from here Super Bright LEDs - Miniature Wedge Base Bulbs (hopefully not illegal in FL).
My plan to extract any shavings that may fall in, is to use a little piece of tape rolled sticky side out and then taped to something that will fit in there.
I really love these "bang for your buck" mods!
Completed this mod over the weekend. Everything went well and it looks great, except I have a problem. The green flasher indicator on the dash stays lit. Whenever I unplug the left bulb, left dash indicator goes off. Same for the right. I didn't read of anyone else having this problem, so ideas would be appreciated!
Background info - I used the same sockets as OP. Also used the same (non-polarized) Jamstrait bulbs. Experimented with other (polarized) LEDs as well. Wired it in the same. I have LED side marker lights. Installed Yamaha specific electronic flasher relay from Cycle Gear. Running light/flasher works as it should. Dash indicator slightly modulates brighter as signal flashes. :confused0024:
