CrazyBiker
Spare some for the Ivan ECU flash!!!
Ballmead, did MotovationUSA use your photos for their site? The pic on their product page is the same one.... or is that not your pic?
Forget the end of the week, I just placed the order for them. $460 with free shipping. Going to inquire for the ceramic guys now.
Next stop is the Dyno!
Hey Eric,
If those Arrow headers work as well as the Yoshimura, then you are going to love them. The power on my bike is much more meaty from 3K up.
Too funny, I'm leaving the office right now to drop parts off at Jet Hot.
That is right! They are right in your neighborhood Pete.
One question (for all) is would you do the 1300 or 2000 temp? I selected 1300 when filling out the questionnaire online. The reason I did not select the 2000 is because it was described as a "rough and gritty surface" so I'm thinking "How does THAT improve exhaust gas flow?"
Not sure that the 2000 degree one would be applied to the inside as I'd have the same concern as you. Just be aware that even with the 1300 degree one you may get some discoloration near the head after a while, especially if you're running a little lean. This is not anything other than a cosmetic issue as the coating will still be fine. I point this out as that was my experience years ago with a ss car header that I had ceramic coated.
, the bike immediately heads over to the Dyno shop for a custom tune![]()
Think about loading the Duke averaged/Papa Geno map before you drop it off.
Should be a pretty good map for your mods. That may speed up the custom tune and save your bike some unnecessary wear and tear on the dyno.
Maybe even save you a few bucks if its real close and they get your bike dialed in quickly.
Guess we should see some pics tonite![]()
