Long day, but done...
I've had the parts for doing the 'N' model headlight conversion collecting dust for awhile, but finally brushed it off. Was waiting for the the 10k mile mark so I could make the most of the tank being off.
First thing was pulling the tank, air box, and filter....only to find this!
Mice, nice! DSPO must've stored it outside a lot, but that won't be a problem anymore. Dug around for chewed wires, but luckily found none. Can't believe it was running as well as it was with all of that junk in the way. I blew the filter out, and reinstalled until my K&N replacement gets off the brown truck.
Next was to open up the air box, ala Lars style (note, pic shown before finish sanding):
After that I pull the smog junk, and slapped on some Roth block-off plates. For those that are considering these, they're a serious bargain for what you get....even though all they're doing is covering a hole. Too bad you can't really see them once installed.
From there I changed the plugs, sorry no pics, but they needed it. Got sticker shock when picking them up at the dealer though. ~$30 for a set!? :eek5:
Moved on to the throttle plates, and installed CD's set. Was too lazy to make my own.
A shot of the modded box, showing flies too:
Next I tackled the headlight. Thanks to this forum I did a ton of reading beforehand, and it paid off. I printed off the entire thread list from when 'MotovationAccessories' (do a search, or I can send you the PDF that I created) did his write up. For those going this route, it's a great resource! Overall it was a lot easier than anticipated, and the results were more than worth the effort.
My favorite view...
Last, but not least, I changed the oil and filter.
It's a different machine now. I liked it before, but now I'm starting to fall in love. Performance is noticeably improved, but am leaning towards a PC V. That's for another post though....:rmwl:
Thanks,
Luke
