sychodan
Hi Beast,
may i ask you why you prefer a non modded air box?
Best regards ,
dan!
Best regards ,
dan!
If I was starting from scratch now, I would....
Junk any Yamaha 2006 ECU if present. 2010 or later preferred.
Slip on exhaust (not too loud to keep police happy)
Block off the AIS hose. Or build AIS blockoff plated if you happen to be changing the plugs at the same time.
Stock air box including filter
Tied secondary throttles
PC5 running MAP based tuning (Several of us have maps to start with)
DJ Autotune module running closed loop and feeding the LCD-200 with data logging
or
Innovate lC1 feeding a flat 13.3 AFR back to the ECU and have a digital display to give AFR at WOT
Beast
PcV&Autotune&LCD 200 goes way too much money!!!
we talking about 750€ without the cost for dyno/tuning....
I think i will stay at the mod's already have!!!
Stock airbox with stock air filter
Racefit slip-on(probably the most awasome exhaust at the world)
Cat gutted
16T front sprocket
with slightly sport riding at 6-7500 rpm i have about 6-7lt/kmh....
not bad i think....
No need with dyno tuning with this setup. You can do that part yourself. It is still not cheap.
Beast
Beast's map is for a system using the autotune, and MAP based tuning. It will not be appropriate for your proposed system using just the PCV.
For perspective, the PC has been available for the GenII for nearly 6 years. Thousands of maps have been created for just about any combination of MODs and many have been shared and "tested" by the forum community over and over and over again. You should be able to find a decent map in the shared map library that may or may not be able to be improved upon for your specific application by a local tuner.
My personal ride is an 06 with "the full package" of mods (see my signature). I have used both Ivan's E map (which was developed on his 06 specifically for the full package mod assortment) and Duken's perfection map. Both yield wonderful results.
Is a PCIII or PCV using "standard" TPS based mapping going to give you as good results as Beast's autotune and MAP based setup? It may come down to whether you are the type who wants to tinker with his/her bike or the type who simply wants to ride and enjoy the machine. So far I am more of the latter and am willing to settle for 90% good on the tune as it really is pretty damn good!
.... So far I am more of the latter and am willing to settle for 90% good on the tune as it really is pretty damn good!
How do you know if you are 90% there without having any idea what 100% is?
Just asking...
Beast
Ditto. All this MAP based tuning is expensive stuff not meant for most of the riders. Frankly, this tuning with a corked bike is pointless and incomplete.Actually my gut tells me its more like 95% but in the end I can really only know what I experience every time I get on the bike. Perfectly smooth and linear power. There are no hiccups, and as best as I can tell there are no adverse effects to the temp ranges that I ride in (40s to 90s). There is also absolutely no question that the power output for the full package and appropriate maps that I have tried (Ivan's, and Dukens) is a world away from the stock bike.
I also know that the mods I run have a long history of development, both in the garage on the dyno, and on the street. There are years of posts from forum members who tried them out and gave their thoughts. There are also abundant dyno sheets available to evaluate.
Do I know for sure that it could only be at best 10% better? No, but like I said it is really damn good.
I've asked you before Beast if you have ever ridden a fully Ivanized GenII? Basically do YOU know what the "90%" is? Don't think I ever got an answer. Have you used your approach to tune a PERFORMANCE oriented GenII project with whatever mods to you feel appropriate (filter, flies, airbox?, full exhaust etc etc). How would the two compare? Will we ever know? . . . . . .
Finally yesterday I received and installed FCE and lcd 200.
Fce seems work properly.
In Lcd 200 there is something wrong because no data is shown. Any idea?
My set up is PCV + autotune + lcd 200
If I recall, you have to set up your display and the output channels to the SD card. Those things can not deal with SD cards larger than 1 gig.
It the CAN network terminator on at the end of the CAN chain?
Andy
