Well I made some headway this week.
New Avon Roadrider tires installed. They appear to be a very nice nice tire.
Kept cleaning; I still have many more hours of de-grunging remaining. I'm going to shift gears and use chain cleaner to spray parts down. I'm also tempted to buy a HF parts cleaner.
Received the MAC 2:1 exhaust. Nothing fancy, just mild steel, and a chrome muffler.
My bottle neck is waiting for parts from Yamaha and Bike Bandit; exhaust gaskets, exhaust nuts, brake pads/shoes/lines, cables, fork seals, etc, etc.
The BMW shock is still in route too. Taking USPS 10 days to get it from SAC to OKC...
I've still got a few ideas I'm mulling over.
1) Front wheel, I have an '84 FJ600 18" on the way. I think the rotor size is the same as the XV, 265mm (tiny). The 18" wheel is much wider, 1.85" vs. 2.15".
2) Bars, I think I'm going to remove the standard bar, slide the forks up about 1.75" and mount clip-ons on the top. With the 18" wheel, and the drop, rake and trail will increase. Wheel first, then clip-on, one thing at a time. I don't want to make too many changes at once as I want the bike to perform well.
3) Rear wheel/rear end, I'd like to install a matching FJ600 Rear Wheel but that presents a host of challenges. a) how to convert from drum to disc brake, b) how to convert the enclosed 630 chain, to an exposed 530 chain, c) making the correct spacers. The main reason I want to change this out is for a wider wheel. 2.15" vs. 2.50" With that I can easily run a 130mm tire, maybe a 140mm. The good thing is Avon makes lots of sizes for vintage bikes.
Opening enclosed countershaft assembly
Massive size of sprocket
View of subframe/airbox/swingarm pivot. Pretty cool engineering really.
NO visible wear on sprocket. I assume this is the original one.
Clean, clean, clean
Clean some more...
