Clean, clean, scrub, scrub
Well I made some headway today. Took some large parts off and cleaned.
I took her for a real ride today and in a word, she is
slow.. But that's okay it's a for a fun bike. Now while she isn't fast she pulls pretty well. The power drops off at about 6,500 to 7,000...no mass.
The brakes are terrible. New lines and pads will make a huge difference, but not anywhere FZ1 standards, let alone R1.
Here's a few photos from today.
Interesting backbone frame, very compact to for the time, and the frame is the airbox! Note the intake boot from the carb going into the frame. Crazy.
Here's where the actual air box with the filter bolts on.
Card breather tubes welded onto the frame.
Massive battery! Next to it is the Aprilia battery. You could start a car with this thing.
Mono-Shock. Happily I discovered it already has a Progressive Suspension spring. No preload however, as the shock used air so preload adjustment. I've not idea if it will hold air.
Based on this sticker I suspect the YZ swingarm will bolt right up. The stock swingarm has cast steel parts! We have come soooo far in the last 30 years. And even if the YZ swing arm is a little shorter that is okay.
I did some research today and learned that RZ350/FJ600 wheels will work well and let me get into better rubber. The XV wheels are 19X1.95, and 18X2.15. The FJ wheels are 18X2.15, and 18 2.50. They should be much lighter, and as they are wider support the tire better. All good things. I'm also considering going with an FJ fork, 1) the legs are the same diameter as the XV, 2) I can use the FJ brakes, and larger rotors. I'll look for an R6 front M/C.
