Okay! It's picture time! I ran straight from work into the garage. I needed to get something substantial done this evening. My main goal was to remove the rear shock, rear swingarm, and get the rear of the motor clean so the rear end could be buttoned up and crossed off my list.
I removed the shock with no problems.
As you can see with the shock removed there was still some grime that was just bothering the heck out of me.
Next I removed the swingarm nut and removed the bolt.
The great lift Dave (Earlzach) gave me came in handy to secure the bike while the swingarm was removed. I didn't want to rely on just the wood stand.
The swingarm came out easy as pie!
I checked the axle and bearings and regreased everything once I saw that the bearings looked like new. There was zero play so everything I suspect was within spec.
I started cleaning all the crevices I couldn't reach when the swingarm was installed.
After all was greased I re-installed the chain guide and end caps and made ready for installation.
Before re-installing the swingarm I got to cleaning the rear of the motor. I removed as much dirt as I could. Some of the "cast" pieces have a texture to them and are not smooth, making it hard to remove every bit of dirt.
I cleaned up the dogbones and shock perch before installation of the swingarm.
The swingarm went back in perfectly and has no side play whatsoever. She's all greased and looking good.
I re-installed the "now clean" rear shock and tightened everything down. I can now say that the rear end is done. I only need to mount the Bridgestones, chain and new sprockets and then I can concentrate on the front end which should go much quicker.
I was happy to get in the mail today, the December 1996 edition of Cycle World which featured the YZF in Black and Gray. I only hope that the bike comes out looking close to this one here!
So tomorrow I will try and get at least the rear tire mounted so that I can get the bike rolling again. I also am waiting for the Chain Tool which didn't make it by the time I left work. I really wanted to have that for tomorrow but I guess I can sand down the exhaust in the meantime. Stay tuned tomorrow for some more updates. Thanks for looking!:tup:
