fencer56
I bought a used 2007 FZ1. For the first two weeks the bike ran like a dream, but last Sunday when I fired it up to go for a ride, I ran into a problem I've never had with any of the three bikes I've owned. The bike started and warmed up as usual, but as soon as I shifted into 1st gear the engine stalled out. It didn't matter if I shifted into 1st of 2nd, the result was the same. I thought there might be an issue with the clutch tension but the only adjustment mechanism I saw was the adjustment screw where the cable met the lever. I tried loosening and tightening the screw but the results were the same at either extreme. My other thought was that it may be an issue with the idle, but the engine seemed to be idling at about the same rpm level it always did. Has anyone else had this problem? If so, what did you do? I can't even ride the bike over to the shop! Help!
