Looking for Gen2 OEM bellypan (any condition)
IBcivic
...as long as it isn't melted....:banghead:
Running a supercharged FZ1 on a dyno will turn a plastic bellypan into Jabba the Hut:(
180+hp 84ft/lbs baseline , then it lost power :(
I found the reason, yesterday... the throttle bodies had popped off the boots and were probably leaking prior to that. (hence the 180hp) going back to the tuner on monday
As a precaution, I will strap the plenum down.
Ive been riding it as is and it is scary fast ...5th gear accelerations feel like 2nd gear accelerations. :Rockon:
Once tuned, I am going to change the final drive ratio from 16/45 to 17/41 which should bring down the revs by 1k in 6th
If its going to melt, why not try a glass one?
I am considering an f-glass replacement for that reason and cost.
Keep in mind that there is a quite a difference in airflow between riding and a dyno blower. I doubt I will be holding the redline for more than a few seconds at a time on the street.
End thread...ended up ordering a carbon replica of the oem pan:cheerleader:
Note>>Not gonna test this pan's heat resistance on the dyno:p
