FZ1riderNY
Moderator
You could probably strip that AIS system right off with no problem. Like Tony said it's nice and clean!
Ive pulled all the plugs, they are in excellent shape. I turned it over by hand and everything feel very good. The engine is in much better cosmetic shape than what I have already, so hopfully its just as beautiful mechanicly
Can someone change the name of this thread to engine swap? I will start a new thread when I fix the other engine. Thanks
WhileI'm working on thebike,I have some LSL rearsets on the bike, and I dislike them a lot. Does anyone have oem rearsets linkage and and brake and shifter levers
688 shipped to my door. 488 for the engine and 200 for shipping.
That's about what I paid for mine but yours has less mileage and doesn't have any road rash. I had to move some of my crankcase covers over from my old motor. The good news for me though is the new donor engine purrs like a kitten.
Good luck on the swap!
The bike runs fantastic. Shifts 100% better than the old engine. It appears I may have a slight coolant seep. It seems to be seeping just ever so slightly right around the housing that you drain the coolant from. I checked the coolant drain plug, its tight. Theres also an allen head bolt that goes into the block that holds the hard coolant line . Its tight. It seems to be seeping around that general area. Does anyone have any insight?
