As with ASV, Pazzo or any other, I am taking them at face value. Actually, ASV doesn't come right out and specify the alloy they use. That took a lot of digging to discover their product make-up.
I don't want them to bend or break, but the design of the long levers for both Pazzo and FDB are the same, where the cut-out for the break-point is the same leaving a shorter lever that is still of use. The ASV, as we know, will not bend or break in a typical crash as they rotate completely around so that the lever end can almost touch the center of the handle bars, then snap right back.
I agree and see your point that the softer alloy will bend first but with both designed with the same break point, the end result *should* remain the same... a usable shorty.
