- Admin
- #1
According to BMW, the S1000R engine puts out 160 hp at 11,000 rpm, and 83 pound-feet of torque at 9,250. More intriguing, BMW says the “ride-by-wire” E-gas engine puts out 7 more pound-feet of torque than the S100RRs engine below 7,500 rpm. Much of the improvement in low-end response, says BMW, can be attributed to redesigned cylinder head ports, modified cam profiles and revised engine management.
Torque! :sinister:
I'm looking forward to read the coming shootout articles.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
An Ivanized FZ1 will mop it up..![]()
With 160 hp at the top end and oodles of torque, I seriously doubt it's going to feel slow.
Without a faring you will struggle to hold on in the higher rpm.
Sent from my GT-I9300
So you think that an Ivanized ECU will get an additional 20-ish horsepower and 5-7 lb*ft torque? Anybody got a dynochart to prove this?
That 160hp is BWM'S rating at the crank......... Just for comparisons sake Yamaha rates the FZ1 at 150hp at the crank and they run 126-130hp on the dyno ( stock )
I'd imagine at the rear wheel on the dyno where going to see about 140hp or even less.
Wow, so basically you can get a used Gen II and throw $2000 at it to get numbers at around the same as the Tuono or S1000R for the engine. Then you throw another $2000 at it for suspension upgrades. And you still save $5000 over either of those fancy euro bikes.
