- Admin
- #1
FZ1inTX
Adminstrator
Over the last week, I am experiencing a very strange issue with the bike. When cruising in any gear and at any speed with the RPMs in a steady state between 3k and 6k... the bike feels like it is hesitating/lurching/catching. It is slight but definitely noticeable. When it is doing this, the tach never fluctuates at all. The RPMs indicated remain very steady.
I have new NGK CR9EIX Iridium plugs on the way (12,500+ miles now) and when I put these in, I intend to remove the AIS system and install block-off plates then sync the throttle bodies with the Morgan Carbtune II. Also, I will be changing the oil and filter, flushing the cooling system and putting Engine Ice in. Last, replacing the air filter.
I have warmed the bike to 200 degrees and sprayed water on the headers with a spray bottle. All four pipes evaporate the water at the same rate.
Any ideas on what this might be? Paranoid delusion? Transmission problem/clutch slipping? Is the hesitation really in the engine and happens so quick that the tach cannot register the fluctuations? TPS going bad?
If I open her up with a ham-fist, it seems to go absolutely full speed without hesitation. If I an decelerating, there's no indication of a problem. This is only at steady speed/RPMs.
Brakes are not pulsing and the wheels spin freely in stands....
One other thought... I need to research. Can a SpeedoDRD cause this if it is malfunctioning? I can unplug and bypass that easily and test though.
So what I am not thinking of and what can I test? All the other items happening soon will rule out a lot of things and I HOPE that one of these is the issue and this resolves it. Thanks all!
