Mine runs fine on all the 87 (or whatever regular gas is) that I have put in it.
Can't tell any difference.
Random answer.........I have a very very very random question, if the TPS is adjusted incorrectly it would show the wrong rpm right, my bike likes to be "idling" at 2500 rpm and when i set it to 1100 on the gauge it get very unhappy when I apply throttle as it in burps and then slowly revs up but if i set it to 2000 ish rpm as the idle it revs perfectly off of idle, so im wondering if the tps is wrong and im setting it to like 500 rpm when it says 1100 and 1100 at 2000 rpm on the gauge, also I have no way to measure the rpm
Good answer and I'll add that I bought some super long screwdrivers for this task and have never regretted it. Makes adjusting the screws easy.Random answer.........
https://www.cartestsoftware.com/fz1/throttlepositionsensoradjustment.html.
Pat's page shows how to adjust TPS using the procedure in the manual and at the bottom shows how to do it using Ivan's rising rpm method.
If the TPS is adjusted correctly your tach should show 5000 rpm when doing the adjustment (see pat's instructions).
I have loosened my TPS and have moved through the full range of movement while riding and the differences are not very noticeable.
It sounds to me like what your bike needs is a carb balance after adjusting the TPS to the manual or Ivan's method. Unfortunately carb balance tool is about $100 (Carb Tune) or you can find some old mercury tubes (they suck for the environment). Did you clean/rebuild your carbs? If you haven't cleaned the carbs that could be part of the problem.
You might be able to find a small bike shop willing to balance the carbs for you.
see also https://www.cartestsoftware.com/fz1/carburetorsynchronization.html
I'll tell you up front finding those balance screws on the carbs is a bear, It's best to use three individual screwdrivers already plugged into the adjustment screws before starting the process. Also use a powerful small led flashlight to find them.
I have the carbtune, and it uses stainless steel rods instead of the mercury. I paid about $100 for it , but that was 15 years ago. Great tool to have, and will last.welp changed the hose and no issues since , I was gonna tune the carbs but the amazon gauges I got kind of died but before they died they were reading about 100 mm and it says it needs to be about 200 in the manual would that change how the it acts at idle if they are synced together but are synced at to low of a pressure
Sound advice.......Get em all as close to the same as you can. If you loosen the balancing screws too far it's possible to have the balance spring(s) fall out.I have the carbtune, and it uses stainless steel rods instead of the mercury. I paid about $100 for it , but that was 15 years ago. Great tool to have, and will last.
I have seen a lot of people that have tried to get all of the cylinders up to xxx mm because the book had the value listed. Some ended up trying to get the "right" values and ended up turning screws too much and getting into trouble. I only looked for balancing them to each other. I didn't pay any attention to the actual values I was seeing. Maybe when you sync, pick the highest or second highest value you see and adjust the rest to match that one and call it a day. My Gen I ran great, and having them all sync'd together made the bike run smoother.
