- Thread starter
- Admin
- #141
FZ1inTX
Adminstrator
Got my front Eagle Eye amber LEDs installed as markers / alternating signals following the perfect instructions on this forum... thanks guys!
the hardware store did not have a step-bit, so I used a 7/8 wood bore bit, got it close to all the way through and then one edge gave, the factory must've made it a punch out. When that gave I simply peeled the rest off. I then pressed the Eagle Eye through, tight fit, followed it with a thick rubber washer which I also pushed through into the headlight assembly against the back of the light to help seal the opening. I then mounted a larger washer on the outside to secure it all and snugged up the mounting nut.
I messed up the wiring on the first side, went LED neg to the Neg wire harness... I had to grab the kids iPad to look up the wiring set-up below and fixed it all. I used the 18guage waterproof heat-shrink butt connectors... was able to mate everything up and used the heat gun to melt the sleeve to the wires.
Yamaha Fz1 LED lights installed - YouTube
Well done! Some mods are just trial and error. Nice work and it looks great!
