- Admin
- #281
BroHay
Stihl Loves Trees
I'm going to give them a try with the new wheel setup.
Sent from my DROIDX using Tapatalk
You will love them. The premise is so simple and effective. I saw that you have the angled stems so make sure that you insert them before setting your bead.
Those calipers are going to look great on there! Sunday is not looking good all of a sudden for me, but let me see what I can work out. I want to get the stuff that I have out to you, especially the brake lines.
Don't worry Tony, maybe me and Richiue could run over to you early Sunday and pick the stuff up from you. Also, by chance do you have the socket for the front sprocket nut that I may borrow??? Or if not do you know the size?? Thanks.
I have to say that you are quite the ambitious person. That bike is going to be showroom quality by the time you are done.
Looks like a lot of work but it will all be worth it in the end.
Good job so far![]()
It shouldn't be too bad to drill and tap those two bolts, especially since those holes are not blind.
As for the pulley it's actually missing a chunk, but the cables should still stay put. It's supposed to look like this:
I checked and your right. It is missing a piece which must have broken off. I do have the cables upstairs and I checked them out and since they pull opposite of the "break", they can't pull out from the pulley. I also found the diagram of the EXUP assembly so I don't need the other shot of the valve. I see which way it needs to sit. Thanks Tony for all the help!
Well that sucks!, Hey, you wouldn't have a photo of how the valve is sitting when the pulley is in that particular position would you?? That would help me out big time. Also, I have the socket. It's either 1-1/4" or 32MM. Either fit really well so I'm good. I'll see you Sunday morning first thing. Thanks!
