NJFZ1
Moderator
I want to remove my full fairing brackets and respray them as they need some tlc. This will mean removing those 4 oil pan bolts - is it safe to remove those bolts without draining the oil from the bike? I don't want to spring a leak of the black stuff just because I've stuffed up.
Also are there any tips or tricks I should know before removing those 4 bolts?
Thanks
You can remove them w/o draining the oil, but make sure you put the bolts right back once you remove the brackets. Otherwise, you'll end up with a nice puddle of oil...don't ask me how I know
