scottyd
Wizard
So, standard grade is 10w-40, but if your riding in a hot climate during summer, ie. 95Deg (35DegC) and higher, would you consider a 10w-50 or 15w-50? Or just stick to 10w-40?
But, in a motorcycle fuel dilution is a serious problem which destroys the advantages of oil that will last longer so I do the above.
Why is there more fuel dilution in a motorcycle than a car. The 2nd gen. engines are fuel injection?
So am I clutching at straws with the thought of going from 10W to 15W?I'm using Motul 10W50 at the moment due to the heat and I have no problems. According to the owners manual it is fine to use in hotter temps.
So when you did the change we're you running 10W to start with or was it already 15W?I normally would not enter a oil thread but I must say that I only use Delo 400 15-40 in all the bikes I have owned over the last 5 years or so, 50k on the 96 bandit and when we gave it a strip down for hot cams and JE pots we could not find any wear at all. Mates are running it in MX four stokers, R1, GSXR's and 2 fjr's with great results. I would never pay for a bike oil again, my FZ1 came with Amsoil synth when I bought it and the shifting was crap and the motor a bit noisy, changed out with the delo 400 same day and shifting is great and hardly a whisper from the clutch and valve train.
Yeah Bluey my other want is to change from the Motul 3100 (cheaper semi-syn oil to full syn) If Mobil Aust stocked 10W40 in Mobil 1 4T I'd be happy as.I use Motul 10w40 all year round. The manual reckons 10w40 is good to 40 degrees and when the temp gets up there I'd rather be inside in the aircon anyway. Also the Motul I use is the premium 7100 which is fully synthetic and exceeds the minimum recomended engine oil grade specified in the owners manual, so even if I did have to ride for a short while in temps above 40 I doubt it would be an issue.
My main concern is the change from 10W to 15W with a new motor, well 3500km's on it, so it's almost new.
Are you worried that 15w is too thick for a "new" (although 3500km is in no way new and is well past the "break-in" period) motor? I ran Yamalube 20w50 right from the start with my motor before swapping to Amsoil 10w40 at about 1,500 miles and my motor runs great and does not consume oil. 15w is certainly nothing to worry about... particularly in hot weather.
Yep exactly, you've hit the nail right on the head, I was worried about changing the grade by going thicker. I also thought (and read a few times in other forums - knowing they are personal opinions and not authoritative documents) you only go thinner when the engine is much older, ie 100,000 or older... I just don't want to bring on wear from a bad decision... So (maybe answering my own question here) there's no harm in going slightly thicker as long as you don't go overboard?
Motul 5100 semi-synth. I have very crisp gear changes with this oil and I have used it on most of my past bikes with great results.
Don't get too caught up in which oil to choose, as long as it's 10W40 and meets the manufacturers specifications, you'll be alright.
No matter what oil you use, the most important thing you can do is to change it regularly and for me that is at least every 5000 klms.
