tombraider2
Wizard
Just back from Bike Night up North. Took a ride after and dang near touched Canada, Sounds Great Mr.
Honda always makes plain vanilla, characterless, super smooth bikes but the CBR1000RR is a different beast!
Ah, forgot about the V4s...You have never ridden a Hawk or a VFR 400 have you.
Determined beyond a doubt the the 990 is eating coolant. After overheating several times on my trip due to a failed thermostatic switch, it now is consuming coolant. Not enough to smoke, nor pressure up the system, but sadly undeniable. I put dye in the coolant, and changed the rad cap to eliminate water pump seal and faulty rad cap, but there is only one place the coolant could be going. This means a complete top end tear down and lots of money. With a one bike garage it also means my season is done. I,ll take her out in the morning for one last run, then it gets stripped down. Then I have to price out a total rebuild, and decide whether or not to just do a gasket replacement (the base and heads both have to be done at the same time) or while in that deep, do the barrels, pistons, rings, bearings, valve seats, cam chains, and have a completely new motor. If I didn't truly love this bike (can't think of one I'd rather have as my only bike) then this would be the end of the line for it. What this will cost would buy a DRZ, but that isn't what I want. So much for a new bike this winter, I guess I'll have to settle for a new motor. Aarrrgggg!!
Certainly you don't need a new motor? The bike is what 2 years old? The wear and tear is "normal" for a bike of this type isn't it? If you really need a motor I would be talking to KTM headquarters?
If not... what? you buy another new motor two years from now?
You are used to Japanese reliability. I doubt they would be cheaper to fix, if they had the same issue out of warranty. Look how complex the new Super Tenere is. I will keep you posted for certain.I'm in disbelief. That really seems unreasonable for such a new bike.
Keep us posted!
Ugh. Sorry to hear about the issue.
Today I rebuilt the RZ front wheel again and I think the fork legs are tweaked. The gap between the legs is too narrow for the wheel.
Tomorrow I'll rotate the legs and in theory the wheel should fit. What a pita this bike is.
I'm also very limited by a bad case of tennis elbow i've had since March. It really slowed me down.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
The bike is 4 years old, ( was a year old when I bought it) and now has 67,000 km, 54,000 of which I put on. These motors have gone well over 100,000 miles before rebuild, but overheating can warp a head surface enough to compromise a gasket. Not really the manufactures fault when an accesory (thermostatic switch) fails and bike overheats. Labour is estimated at 20 hours, plus parts, totaling aprox.$3500.00.
I take it there is no external temp gauge? If not will you add one this time?
I purchased a 'gently used' (crashed) 2003 FZ1 on July 8th. I took it (via trailer) to a friends house where I've been working on it whenever I had the time. Initially it had broken motor mounts, leaking fork seals, torn seat, broken rear tail piece, under fender, etc... The list is long. I upgraded it from the Stage I (holeshot) that it already had to stage II w/pods, also from Holeshot performance. I added a few rizoma goodies that I picked up for a good price and spent the rest of the time just repairing everything else. It's basically done now with exception of some fine tuning of the carbs. A bit finicky w/the pods on there. I have an R6 shock kit but I haven't installed it yet. I wanted to get a feel for how it is first, before the 'upgrade'. Here are a few pictures. If you'd like to see the whole project there is an album link below.
Album
