installed wheels with new Power Road 4s...
and stripped my oil drain bolt!!!! It seats but not very tight, I teflon taped it to add a bit of bite to it but I'm afraid of the implications. I ran it around the neighborhood and it did not leak, but I;m afraid that riding longer will loosen...
So, should I tap the hole with a larger size, or replace the entire pan?!?!
Bought a K&N filter at 4WheelOnline.com because of the offered price. I'm not expecting HP gain though hopefully it will make my bike runs even smoother. I also like it because it is washable/reusable.
Yes, as long as that section of the pan is fairly thick, they are made to replace thread`s in heads ,rocker covers, etc, can be used most places where the female thread is damaged. may be best to get it done at a workshop ,if you have no experience in fitting one.
Installed a Motodynamics integrated tail light.
Would have been a quick 30 minute install, if I would have consulted the manual first. Turned into an hour and a half job as I figured out what to take apart.
But that's half the fun of it. :cool:
[video=youtube;d5ht1PcQ0c8]https://www.youtube.com/watch?v=d5ht1PcQ0c8[/video]
There are a few other types of inserts Time-Sert, etc, that can be used, but I`ve only had experience with the heli-coil, ask around your area and see what they use
My R6 rear shock and dog bones arrived to today along with a used Monokey rack I ordered for my first gen. I'll be busy fitting those this coming weekend. :)
I've been riding every day for over a week since my car got destroyed ($9,500.00 in damage) while parked in my apartment's parking lot. The car will be repaired but not until Nov 26th. Good thing I bought decent winter gloves.
dropped it at the shop today for an $80 re-thread, cheaper than all of the parts on-line and less hassle - be back riding tomorrow! Gotta enjoy the 95deg fall weather down here!
Can't bill the perp for a rental?
Went for a ride!
Sent from my SM-G900V using Tapatalk
Spent close to 4 hours cleaning the bike and getting it back to weekday commuting configuration after 3000km of riding in 6 days.
All pretty again
Anyway u can post a pic of what and where the plugs are u hooked the speedo healer upto?
I didnt take any pictures during the process but take a look here
I had to completely remove the tank though as i couldnt reach the sensor's plugs just by lifting it (plus i was a little afraid not to stress the fuel line...).
Out with the old, in with the new.
Unfortunately I couldn't mount the reservoir bracket on the rear pillion bracket bolts as the factory intended because of my pannier brackets. For now it is zip-tied to the pillion bracket instead. If I could mill about 2mm of the pillion bracket then I could mount it properly. I suppose I could file or grind it.
I probably don't need the remote reservoir and could have saved some $$ not getting it but I'm sure it will be better over bumpy, twisty roads than not having it.
Only a short road test after fitting but it quickly became apparent how much better this new shock is at damping. Much less harsh going over the few bumps I encountered and just generally smoother. It also showed up how harsh the front is. Next mod is to re-spring the front.
