NoCal
Hi everyone, I am a new member. What is the first year of the Gen 2? What are the significant differences between the 2 Generations? Thanks for your help
Polestar.... you're close.... but a few things.
Gen II suspension better than Gen 1? HA. No. The Gen II suspension itself is abysmal.
The rear shock on the Gen 1 is rebuildable, and has an external resi. On the Gen 2, it's a traditional shock, no resi. and is not rebuildable... when it starts to get old and bouncy, it's trash. On the Gen 1 rear, you send it off, have it revalved and resprung, and it's almost as good as an aftermarket replacement.
Front suspension. The Gen 1 has the following adjustment in each leg : Preload, Compression Damping, Rebound Damping. The Gen 2? Both legs have preload, one leg has compression damping, one leg has rebound damping.... what a horrible design... There's a reason many Gen 2 owners replace their front suspension with R1 components.
As for weighing less and having a \\"stronger\\" motor.. well that may be true by a few pounds and even fewer HP... but look at the 1/4 mile times on those same charts.... the Gen 1 beats the Gen II in 0-60, 0-100mph, 60ft times, 1/8 mile times, and 1/4 mile times. So, our heavy dinosaur is the winner there.
Braking, as above, the Gen 1 beats Gen 2 0-100mph. It also beats it 100mph - 0. Braking edge goes to the Gen 1.
I wouldn't say that the Gen 1 has more of an emphasis as a tourer. I would say that the Gen II, touring isn't really the best option. It's built for just one thing, and that's sport type riding. The Gen 1 can be toured on... or, like me, you can ride it just as you would a sportbike.... what you give up in sporty position, you gain in ground clearance.... drop the forks 7mm, raise the rear a little bit, and you're good to go....
I have heard about \"fuel issues\" with the 2006 FZ1 can anyone elaborate? Can they be easily fixed or is it better to stay away from the '06? Are there any other issues or years/models I should watch out for?
NoCal said:Thanks for the article link above Bro. One specific question...The article mentions how the Gen2 has an improved trans/gearbox. Is the Gen1 trans/gearbox poor or clunky? Or is it just that the Gen2 improved the trans/gearbox?
I have a gilles rearset on my '01, and it is all the way up and back. I don't have enough clearance to run the shorter shifter. Other than just having some adjustment issues with the clutch, operation has been smooth on the Gen I part.
Adam
