Crispy
I did the pod light mod http://www.998cc.org/forum/gen-ii-mods/1436-pod-mod-lights.html?highlight=pod+mod+lights and everything works as it should, but my green dash indicators stay on constantly. They do modulate a little when I intentionally use signal. I also have LED side lights that only act as turn signals (the cheap kind, not Watsen or Protons) which have worked fine until installing the pods. The problem is there before and after installing a Yamaha specific electronic flasher relay from Cycle Gear. If I unplug left pod bulb, left dash indicator turns off and vice versa for the right. So, does the dash think the lights are "blinking"? Do I need a resistor? Here is a diagram of how I have the left side wired...
