TG1992FZR1000
Does anyone know the brake line length for both sides? How about the orientation of the banjo fittings? Are they both on the same plane or is one side turned 90 degrees from the other ends? Also what about bends on the banjo fittings on master cylinder or caliper side?
The Brembo model master is an M10x1.0 thread pitch.
Right now the lines from my FZR are 26-1/4" and 28-1/2" short and longer sides. Banjos are rotated 90 degrees from each other and don't exactly fit correctly without twisting them a little too much..
I am using 2004 R1 mono block calipers and a 2006 radial master on my old dinosaur FZR1000. Trying to get standard brake line lengths to fit this older bike. I think the calipers are the same as the FZ1??
Thanks guys.
Thanks guys.
