FZ1riderNY
I'm sorry. The picture comes too small when you use the attachment feature.
LOL! It's not THAT big! The garage is 24'x24' and the loft is about 12'x24' and my daughter's crap occupies about half of it!
Billy, that price is fantastic! Is that the foil-faced or the pink rigid Foamula stuff? I wonder why it is so expensive here and we don't even have taxes!!!
BTW, it was the electric 19k BTU heater I bought. That was the least expensive to try out. I've been talking to another guy about a hot water baseboard using solar and a home-built collector but I'd have to build that over the summer and install it on the roof. Take a look at this. Picture this mounted on a true-southern exposure roof with the supply filled with an ethylene-glycol liquid (antifreeze) that has an extremely high boiling point and will not freeze. (This is down the road but cheap and doable!) I'm already on the hunt for one or two broken water heaters to pull the tanks from and start fitting. For the summer, I can put a reflective cover over the tank OR, run it into the house as a pre-heater for the hot water supply for the house. Save on the natural gas bill for the summer. Check out this link for those interested: Solar Hot Water Batch Collector - DIY Solar Shower - Homemade Hot Water Heater - Tankless Water Heaters ? ByExample.com
the only reason I suggest that, is so you can maintain your storage in the ceiling area.... otherwise, I'd recommend sheet-rock and insulating the ceiling... because, you're absolutely correct... not real reason to heat all of the way up...
but.. I think the idea you've got going should work like a champ...
here, we're allowed to insulate the top roof truss areas... hell... we're encouraged to do so... my current place actually is insulated on the underside of the roof trusses, as well as in the ceiling and floor of my place... it's like living in a big insulated cooler.... except that all my dang windows and doors leak like crazy.
