FZ1inTX
Adminstrator
Insulating the garage ceiling?
I own a detached 24'x24' garage. The doors are insulated aluminum-clad and will be sealed fully next weekend. The walls are all fully insulated and sheetrocked. I've still got to trim out the windows and doors inside and insulate the small spaces around them.
My question is, what would be the best way to insulate the ceiling without it being 100% permanent? The garage has loft rafters and is a cape style. This left me with some knee-walls up there after I closed up the loft for storage (so things wouldn't fall out onto the vehicles). I use the leftover rafter space to store items like PVC pipe, spare siding, some wood, etc. I also have several things suspended from the rafters but those can be worked around easily.
I'd like to insulate it enough to hold some heat in for only when I want to work out there in the winter. I'm going to install a small 20k BTU wall-vented gas heater with a blower but I don't want the heat to head up into the loft and out the ridge-vent.
What are some options? Here was one thought I had and tell me if this is feasible? screw 1"x3" strapping across the bottoms of the rafters to provide support for the 2" rigid foam board and fill each space between the rafters with the foam panels? It would take 3 eight-foot panels to stretch from one side to the other per bay, thus 36 panels and she's covered. If I do this, I can then, in the summer, lift the end panels up a bit and slide them on top of the center panel to allow heat to escape when I don't want it trapped. This also still allows me to use the rafter space for the stored items and make them accessible.
Thoughts? Or, is there a better way, maybe cheaper way? I added up the costs for this method and it came to $600 to accomplish the task. This doesn't include the heater.
