I wouldn't be looking forward to it either. How many miles on the bike?
Is that the oil level sensor? The only things I see in the exploded view or the service manual that bolts into the oil pan (other than the bolts to hold the pan of course) is the drain plug and the oil level sensor.
I understand. From reading about peoples experience doing the job it seems to be one that takes practice given that many had to go back in to correct some issue like getting the drain tube inserted correctly.
I think I may have the same thing going on with mine. I had thought the couple of oil drops were from not getting things wiped down sufficiently after an oil change but that does not seem to be the case unfortunately.
