T84A
Do you have stock levers? If not, where did you get and/or who makes the aftermarket ones? I ask because I just bought some aftermarket ones.
Sorry to hear you are having this issue, Eric. Sure seems like you have covered all the bases. Must be the aftermarket lever, if so many others have installed SS lines without this issue. Am a little concerned now, since I just got my Spiegler lines.:eyebrow:
Missy, it's not the brake fluid... I think you've misunderstood me. It is the amount of movement in the lever. With the SS lines, it takes a lot less brake lever movement to go to full lock.
The lever, when squeezed, pushes the plunger to compress the fluid behind the caliper pots. At the very same time, the same lever releases the electric switch to actuate the brake light. This is an on/off switch and there is a point where it clicks. If the lever doesn't have enough movement, the switch will never extend far enough to "click" which was my case. This is an equal and opposite reaction to the action of applying the front brake. You cannot depress the fluid plunger without simultaneously releasing the electrical switch plunger.
I'm glad it's fixed, but here I go... :deadhorse: glue will be had! :ugh:
If there was less fluid and the MC plunger pushed in farther, then the lever would move farther before the brakes caught and thus the plunger on the switch would be allowed to move more and possibly activate the brake light at the proper amount of braking... (not that less fluid is necessarily good, just a thought.) In this manner the amount of fluid in the MC does indirectly effect the brake light, just not directly.
OK, I understand that less fluid in the MC might not effect the amount of travel in the lever because you are compressing the fluid down the line more or less 'excess' fluid in the MC wouldn't change the travel, but that's what I was thinking. The plunger in the MC would have to travel farther to initiate the braking, thus making more total travel. Possibly flawed logic, but that's where I was coming from. :ugh: :chat:
Curious problem. The SS lines should not make that much difference. You should still have "free-play" as the hydraulics have to take up pad knock off. The lever should move maybe 1" at the end, before your brakes start to work.
I got what I paid for in cheap lever knock-offs. Next time it will be Pazzo or ASV. I'll set aside some cash and grab a used set when opportunity knocks. :tup:
Good timing! I should comment that my Chinese knock-off levers are COMPLETELY un-anodized and are silver with a golden hue to them. Now, they still work perfectly after the modification but Black is no longer an option.
