How many miles on your fz1??
Here is my personal Log I keep on the bike.
DateMileageOil ChangedOil Filter ChangedOther Work DoneNotesMiles on Tire/Brakes
07.13.201339000Purchased
08.16.201340693Mobil 1 4MT 10-40Fram ph6017a
08.27.2013New Front Brake Pads
09.16.2013New Front TireMoved from 02 FZ1
11.30.201344900New Rear TireMoved from 02 FZ1 [Bridgestone Sport Touring Battlax BT023 180/55Z 17R M/C (73w)]
03.11.201447752Added some Oil.
03.11.201447789New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA
05.03.201449640New Front Tire
06.24.201451471Mobil 1 4MT 10-40Fram ph6017a
09.05-201453943New Rear TireBridestone Sport Touring Battlax T30 180/55ZR179957
10.08.201455176Fork Seals and Bushing Replaced.
10.08.201455176New NGK PlugsNGK "R" CR9E Use sparkplug tool in bike tool kit
10.08.201455176Radiator FlushRemoved Radiator to get to spark plugs. Refilled. Peak
11.02.201456567Mobil 1 4MT 10-40Fram ph6017aOil Changed.
03.28.201561500New Front TireBridgestone T30 120/70ZR 17M/C11860
03.28.201561500New Gasket Yamaha Part Number 3273697
05.30.201563734Lucas semi syn 10-40Fram ph6017a
06.12.201563900New Rear TireBridgestone T30 180/55ZR178600
10.15.201567711New Rear Brake Pads
01.15.201670680Lucas semi syn 10-40 (3 quarts)wix 51358
02.27.201672500New Front TireBridgestone T30 120/70ZR 17M/C11000
02.27.201672500New Rear TireBridgestone T30 180/55ZR17
06.07.201675680added 9oz oil
07.04.201675948Lucas semi syn 10-40 (3.5 quarts)wix 51358.5 Quart still in Bottle on shelf
11.24.201681494Lucas semi syn 10-40 (3.5 quarts)wix 51358.5 Quart still in Bottle on shelf
02.04.201783000New Rear Tire180/55ZR-17 (73W) Shinko 009 Raven10500
2.27.201783450Valve Adjustment2 shims moved, one replaced. new Plugs, new air filter.
04.15.201785594New Front Tire120/70ZR-17 (58W) Shinko 009 Raven13,094
04.21.201786000Lucas semi syn 10-40 (3.5 quarts)wix 51358 XP
05.19.201787000New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA
07.03.201788000Lucas Semi Syn 10-40Added 1/3 quart
08.01.201789750Lucas Semi Syn 10-40Added 1/3 quart
10.09.201792400seat coveredSOS in oceanside. 1 year warranty.
10.14.201792654New Rear Tire180/55ZR-17 (73W) Shinko 009 Raven9654
10.31.201793449Lucas Semi Syn 10-40Added 1/2 quart
11.08.201793876Lucas semi syn 10-40 (3.5 quarts)wix 51358 XPOil Changed
11.08.201793876New BatteryYUASA BATT YT14B-4 (YT14B-BS) - $119.00
02.23.201897xxxLucas Semi Syn 10-40Added 200ml
03.31.201898180Lucas Semi Syn 10-40 (3.5 qts)mobil1 m1-108
05.23.201899453New Front Tire120/70ZR-17 (58W) Shinko 009 Raven13,859
05.23.201899453New Front Brake PadsRenthal RC-1 Sport Brake Pad - Sintered Double H - Front Left - 2003 YAMAHA FZ157,453
07.31.2018102316New Rear Tire180/55ZR-17 (73W) Shinko 009 Raven9,662
08.17.2018103120Lucas Semi Syn 10-40 (3.5 qts)wix 51358 XP
11.27.2018105756added 200ml
02.24.2019107407Mobil 1 10-40 Full Syn (3.5 qtsFram ph6017a
03.20.2019107980new chainRNK 530, work done at ECC - will need sprockets next time, get steel sprockets.
05.27.2019109831EBC double h sintered
06.13.2019110772motorex 10/50 full syn 3.5 qtsmobil1 m1-108a
08.08.2019112000Fork Seals replaced - $200 Labor - $51.20 parts
10.19.2019113661New Rear Tire180/55ZR-17 (73W) Shinko 009 Raven11,345
10.19.2019113,661New Front Tire120/70ZR-17 (58W) Shinko 009 Raven14,208
01.27.2020115,1403.5 qts Mobil 1 10/40Fram ph6017a
03.21.2020115,800motorex 10/50 full syn 3.5 qtsFilter keptWater Pump Seals, New Impeller, new lower radiator bracket.
08.22.2020118,278motorex 10/50 full syn 3.5 qtsMobil 1 M1-108a
10.18.2020119,500New Rear Tire180/55ZR-17 (73W) Shinko 009 Raven (replaced early due to split from road debris)5,839
12.16.2020120,600Rear Tail Light bulbs changed.
01.17.2021120,714Thermostat Housing Gasket - Added Coolant
01.17.2021120,714New NGK PlugsNGK CR9EIX Iridium Use sparkplug tool in bike tool kit
04.19.2021121187motorexadded some oil
04.20.20211212583.5 quarts Lucas 10/40 semi synmobil 1 M1-108a
04.20.2021121258added brake fluid to rear reservoir
05.14.20221258913.5 quarts Lucas 10/40 semi synfram ph6017a
08.03.2022126652New Rear Tire180/55ZR-17 (73W) Michellin Road 4 - Shinko Blew Out on the Freeway7,152
05.29.20231292923.5 quarts lucas 10/40 semi synmobil 1 m1-108a
07.17.2023New Front TIre
Could you tell us your tire blow out story? Cause? How did the bike react?
Lol this thread makes me feel somewhat less like a complete dork. I have a spreadsheet too, very similar to the one above. My 08 is approaching 50K, only 8K of which are mine.
Ok still probably a dork. :)
Not a dork dude. Been keeping a log since 2008. Haha. It helps!
Now you guys made go look at my notes...almost 800 fuel trips and 72 service records
And now that I looked on the Fuelly site, a large % of the records reported are from me :D
The miles I've put on bikes:
1972 Triumph Trident. 1000 miles couldn't keep it operational long enough to ride
1974 Kawasaki Z1 45K miles including two trips across the USA (Still own)
1982 GS1100ez 106K miles only one trip cross country. (Still own)
2001 FZ1 285K miles replaced motor at 150K (Still own)
2001 FZ1 55K miles Current daily driver (Still own)
I can do you one better - I run my GoPro when commuting and caught the entire thing on film:
Whoa, crazy man. Glad your Ok. Didnt seem like it blew out till you looked at it. Something I have always been curious about. Did you pick up a nail or did the tire just fail? And, can I ask why you gopro your commutes? No judgement, just curious.
I feel like the tire just failed and exploded from the inside and because of this being the second Shinko Raven to fail early I have changed over to to Michelin tires. I did not hit anything that I saw or felt - does not mean I did not hit something..... I just did not see or feel anything until the tire delaminated.
I run the GoPro on my commute for a few reasons:
  • I have caught some interesting things over the years and posted them to my YouTube Channel
    • lady using a laptop at 65mph... both hands on the keyboard, laptop on her lap and steering wheel.....
    • Road Rage incident on the 78 where a car purposely hit another one and flipped over (The viral video was a driver with a cell phone, but I caught part of it at the same time riding by)
  • "Just in case" someone does something bad to me.
    • This happened once to me before I had a GoPro and it was a he said/ she said deal with the insurance so we we both considered at fault. Now I will always have video evidence to add to any situation.
  • To show just how safe Lane Sharing can be (been doing it since 2011 without incident)
good deal….thanks for sharing.
I just moved from Seal Beach this past summer. Lived there for 2 yrs. And lived in the bay area for 3 yrs before that. In Louisiana now. Love it down here, but I do miss lane splitting.
