| Date | Mileage | Oil Changed | Oil Filter Changed | Other Work Done | Notes | Miles on Tire/Brakes |
| 07.13.2013 | 39000 | | | | Purchased | |
| 08.16.2013 | 40693 | Mobil 1 4MT 10-40 | Fram ph6017a | | | |
| 08.27.2013 | | | | New Front Brake Pads | | |
| 09.16.2013 | | | | New Front Tire | Moved from 02 FZ1 | |
| 11.30.2013 | 44900 | | | New Rear Tire | Moved from 02 FZ1 [Bridgestone Sport Touring Battlax BT023 180/55Z 17R M/C (73w)] | |
| 03.11.2014 | 47752 | | | | Added some Oil. | |
| 03.11.2014 | 47789 | | | | New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA | |
| 05.03.2014 | 49640 | | | New Front Tire | | |
| 06.24.2014 | 51471 | Mobil 1 4MT 10-40 | Fram ph6017a | | | |
| 09.05-2014 | 53943 | | | New Rear Tire | Bridestone Sport Touring Battlax T30 180/55ZR17 | 9957 |
| 10.08.2014 | 55176 | | | | Fork Seals and Bushing Replaced. | |
| 10.08.2014 | 55176 | | | New NGK Plugs | NGK "R" CR9E Use sparkplug tool in bike tool kit | |
| 10.08.2014 | 55176 | | | Radiator Flush | Removed Radiator to get to spark plugs. Refilled. Peak | |
| 11.02.2014 | 56567 | Mobil 1 4MT 10-40 | Fram ph6017a | | Oil Changed. | |
| 03.28.2015 | 61500 | | | New Front Tire | Bridgestone T30 120/70ZR 17M/C | 11860 |
| 03.28.2015 | 61500 | | | | New Gasket Yamaha Part Number 3273697 | |
| 05.30.2015 | 63734 | Lucas semi syn 10-40 | Fram ph6017a | | | |
| 06.12.2015 | 63900 | | | New Rear Tire | Bridgestone T30 180/55ZR17 | 8600 |
| 10.15.2015 | 67711 | | | | New Rear Brake Pads | |
| 01.15.2016 | 70680 | Lucas semi syn 10-40 (3 quarts) | wix 51358 | | | |
| 02.27.2016 | 72500 | | | New Front Tire | Bridgestone T30 120/70ZR 17M/C | 11000 |
| 02.27.2016 | 72500 | | | New Rear Tire | Bridgestone T30 180/55ZR17 | |
| 06.07.2016 | 75680 | | added 9oz oil | | | |
| 07.04.2016 | 75948 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 | | .5 Quart still in Bottle on shelf | |
| 11.24.2016 | 81494 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 | | .5 Quart still in Bottle on shelf | |
| 02.04.2017 | 83000 | | | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 10500 |
| 2.27.2017 | 83450 | | | Valve Adjustment | 2 shims moved, one replaced. new Plugs, new air filter. | |
| 04.15.2017 | 85594 | | | New Front Tire | 120/70ZR-17 (58W) Shinko 009 Raven | 13,094 |
| 04.21.2017 | 86000 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 XP | | | |
| 05.19.2017 | 87000 | | | | New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA | |
| 07.03.2017 | 88000 | Lucas Semi Syn 10-40 | | | Added 1/3 quart | |
| 08.01.2017 | 89750 | Lucas Semi Syn 10-40 | | | Added 1/3 quart | |
| 10.09.2017 | 92400 | | | seat covered | SOS in oceanside. 1 year warranty. | |
| 10.14.2017 | 92654 | | | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 9654 |
| 10.31.2017 | 93449 | Lucas Semi Syn 10-40 | | | Added 1/2 quart | |
| 11.08.2017 | 93876 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 XP | | Oil Changed | |
| 11.08.2017 | 93876 | | | New Battery | YUASA BATT YT14B-4 (YT14B-BS) - $119.00 | |
| 02.23.2018 | 97xxx | Lucas Semi Syn 10-40 | | | Added 200ml | |
| 03.31.2018 | 98180 | Lucas Semi Syn 10-40 (3.5 qts) | mobil1 m1-108 | | | |
| 05.23.2018 | 99453 | | | New Front Tire | 120/70ZR-17 (58W) Shinko 009 Raven | 13,859 |
| 05.23.2018 | 99453 | | | New Front Brake Pads | Renthal RC-1 Sport Brake Pad - Sintered Double H - Front Left - 2003 YAMAHA FZ1 | 57,453 |
| 07.31.2018 | 102316 | | | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 9,662 |
| 08.17.2018 | 103120 | Lucas Semi Syn 10-40 (3.5 qts) | wix 51358 XP | | | |
| 11.27.2018 | 105756 | | | | added 200ml | |
| 02.24.2019 | 107407 | Mobil 1 10-40 Full Syn (3.5 qts | Fram ph6017a | | | |
| 03.20.2019 | 107980 | | | new chain | RNK 530, work done at ECC - will need sprockets next time, get steel sprockets. | |
| 05.27.2019 | 109831 | | | | EBC double h sintered | |
| 06.13.2019 | 110772 | motorex 10/50 full syn 3.5 qts | mobil1 m1-108a | | | |
| 08.08.2019 | 112000 | | | | Fork Seals replaced - $200 Labor - $51.20 parts | |
| 10.19.2019 | 113661 | | | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 11,345 |
| 10.19.2019 | 113,661 | | | New Front Tire | 120/70ZR-17 (58W) Shinko 009 Raven | 14,208 |
| 01.27.2020 | 115,140 | 3.5 qts Mobil 1 10/40 | Fram ph6017a | | | |
| 03.21.2020 | 115,800 | motorex 10/50 full syn 3.5 qts | Filter kept | | Water Pump Seals, New Impeller, new lower radiator bracket. | |
| 08.22.2020 | 118,278 | motorex 10/50 full syn 3.5 qts | Mobil 1 M1-108a | | | |
| 10.18.2020 | 119,500 | | | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven (replaced early due to split from road debris) | 5,839 |
| 12.16.2020 | 120,600 | | | | Rear Tail Light bulbs changed. | |
| 01.17.2021 | 120,714 | | | | Thermostat Housing Gasket - Added Coolant | |
| 01.17.2021 | 120,714 | | | New NGK Plugs | NGK CR9EIX Iridium Use sparkplug tool in bike tool kit | |
| 04.19.2021 | 121187 | motorex | | | added some oil | |
| 04.20.2021 | 121258 | 3.5 quarts Lucas 10/40 semi syn | mobil 1 M1-108a | | | |
| 04.20.2021 | 121258 | | | | added brake fluid to rear reservoir | |
| 05.14.2022 | 125891 | 3.5 quarts Lucas 10/40 semi syn | fram ph6017a | | | |
| 08.03.2022 | 126652 | | | New Rear Tire | 180/55ZR-17 (73W) Michellin Road 4 - Shinko Blew Out on the Freeway | 7,152 |
| 05.29.2023 | 129292 | 3.5 quarts lucas 10/40 semi syn | mobil 1 m1-108a | | | |
| 07.17.2023 | | | | New Front TIre | | |
