fostytou
Fuel in the US uses a different rating (AKI) than fuel outside (most) of the US... 87 AKI here is 91-92 RON outside of here. US 93 AKI is 98 RON outside of here. Same fuel, different standards of measurement.
For more info on this there is decent information on wikipedia:
Octane rating - Wikipedia, the free encyclopedia
There is also a chart that compares AKI to RON for many typical fuels.
And yes, I am in the boat that use the minimum octane required. If you have a jet kit or a timing advancer and either specifies to use a higher octane fuel then it may be needed. When I'm racing or doing a spirited mountain run I go for a little higher octane. Hot spots in an old engine can develop on carbon deposits and make knock more likely, higher octane helps to prevent that.
That said, I don't think using premium will lower your power significantly or noticeably. Not any more than 2 back to back runs on the dyno would be different. Higher octane fuel burns slower and, more importantly, more consistently. Knock happens when the explosion starts somewhere other than the center of the cylinder / spark and pushes in an odd direction. The explosion has to be timed properly to push the piston and rod down with maximum force, but not so soon or off-center that it pushes them before they reach the top of their stroke.
