delbert
Wizard
Up on the front / down on the back would make it higher geared thus dropping the revs ,, on a carriage way I'm sure it would work , I have heard of a guy that did this for touring ,, that said you will probably be on the loosing side when not cruising as you may need to be in a lower gear , swings and roundaboutscould/would going up a tooth or two on the front or rear sprocket improve mpg
