Bagzter
Hi guys, i just put some Oxford Products LED Nano indicators on my bike, 2007 FZ1, and find i have a problem with the hazard lights. The indicators work fine with the correct flash rate, but, when i put the hazards on they flash once and then no more, the indicators wont work then unless i cycle the ignition.
I know they worked fine before i switched to the LED's, so, is this a case of the relay wont handle the LED's or is it a sure sign its on its deathbed?
If its due to the relays not handling the LED's can anyone recommend what relay i should use.
Note: i have used the ballast resistor that comes with the kit as it set the flash rate correct.
