Gen2 Headlight adjust screws
Which screws do you use to adjust the headlights?
I installed a R1 shock using Satan's adapter and that raised the rear so now the headlights fall short on low.
You probably didn't see it but I posted somewhere that before changing the shock out you should mark on a wall your headlight alignment before so you can then adjust it to the correct level after. Hopefully this might help someone else.
