geezer
A friend had these made for me quite a while back. They just sat around, waiting for me to have time to install them. Yesterday, I found the time. The difference is night and day! Just thought I'd share. Thanks Don!
Stainless steel brake lines , do make a noticable improvement to the intial bite & feel of the brakes .
correct, in rubber lines, especially after some mileage, the pressure is also expanding the rubber lines, where you want the pressure go 100% to your brake pistons. The rear brake is not that crucial, but I would (and will) replace my front rubber lines at least as from 5000km....I replaced my previous bike (Diversion) rubber with metal lines, and the brake effect was huge.....I even made an (unforeseen) stoppieSo how's that work? I suppose rubber lines do expand a bit and reduce the pressure in the lines compared to thee metal reinforced lines.
That seals the deal for me. Gonna go with the stainless.
The Brembo's are just the pads? Your staying with the stock calipers?
Sounds good. Post some pictures when everything is done with the brake system. I am going to pick up the Red Caliper Paint Kit from Duplicolor to do the front and rear calipers. It should go really nice with the wheel stripes. I'll post some pics when I am done.
Stainless Steel brake lines are one of the better bang for the buck mods. They really do make a big difference in the feel and more importantly the feedback through the brake lever.
I'd suggest not buying Galfer as their bolts and fitting tend to rust.
