FZ1inTX
Adminstrator
I've just submitted a question to them regarding this so they will be aware of it soon. Good call! :tup:
Sorry if I've misled anyone but what I said was "For those that used the stock bushing, how did you get theirs out?" meaning "For those that used the stock bushing, how did you get theirs (Fire Dragon Brothers bushing) out?"
Yes, the stock bushing in the stock lever practically falls out on its own. I think only the grease holds it in.
Well FDB should have done what companies such as Pazzo or CRG do...you reuse your old bushing from the stock lever so that there are no fitment issues.
Like I said previously you use the stock bushing to press out the FDB one. But you'll need a small press to do it.
What? How about a hammer and a pair of vise grips? :eek5:
I think I have a way to press it. Will try it this weekend while it is raining!! :looseit: :cheers:
Thanks!
A vice, the stock bushing and some small sockets should do the trick as well
Place the lever in the vice with the factory bushing over the one in the lever. On the other side of the lever place the open end of a socket that's big enough for the bushing to fit into. Now clamp the whole thing in the vice and keep tightening it. I can't see how that bushing wouldn't come out
firedragonbros2009 said:Hello there. You can press out the copper collar out if you think it is not suitable and put your own bushing in. I recommend you doing this with a bench clamp. Hope you can do it.
Thank you!
Should have got the black with blue adjusters and the extendable foldable ones - they are only $20 more. And those dunlops need to go into the bin. OMFG, see the difference between those and the PP2CTs.
those foldable ones are sweet did you buy a set Crazybiker?
Yes, I know about the tires... Like I've said before, I'm too cheap to get rid of them until the time is up which is real soon now. :cheers:
