FZ1inTX
Adminstrator
You get to do so much stuff at work ? Did you shave off the nubs on the controls since they don't fit right without holes drilled and the throttle sticks.
Today is a WFH (Work From Home) day so this is all basking in the sun with the laptop at the table in the garage.
I didn't move those controls, only the brackets for the levers. The controls were moved at the same time by rotating the whole bar down a bit. :tup: Then, I rotated the levers into position and tightened.
