rjafz1000
Cool thanks I might try this
Sent from my Nexus 7 using Tapatalk
Wind the needle past about 6k (from memory) by hand. It will then take off by itself and stop at about 7 0'clock. I call this the park position. Mark that spot. When reinstalling put it in the marked spot and wind it back to about 6k it will go back by itself to the stopper pin. Done this quite a few times and the revs seem correct. Don't push the needle on too far. It will bind and you'll think you've stuffed your tacho. Don't ask how I know!
If you have a PCV, you can check your Tacho by plugging in the PCV and opening the program on your lap top and comparing the revs displayed.
Huh I just remembered where it's normal idle was at and then when I went to reinstall I started the bike and let it idle and re installed the needle to the correct idle revs. Haven't had one issue and was simple.
