So far so good, I just have to bolt the float bowls back on and put the top caps back on.
The All Balls kit comes with a ton of o-rings, screws, needles, washers, jets, float needles, and float needle holders. All seem good quality but not everything is marked the same as the original Mikuni parts. For example only the main jets have sizes marked and they're exactly the same as the stock sizes, staggered 130 and 132.5.
I didn't use any of the included jets. The tips of the mixture screws looked thinner than my stock screws so I didn't use them either. The float needles and needles holder are good and I definitely needed those.
Overall it seems like a good kit. If I would have sourced the bowl gaskets, misc o-rings, and float needle assemblies separately I probably would have paid the same ($100). I'm just glad it came with new screws for everything. Most of my existing screws were reusable except the threads on the screws that hold the float bowl pins down got mangled. Good news is the replacement screws fit fine. The real test now is if the bike starts and runs.
I am following the RavenRider jetting, since that worked so well on my Silver bike, sourcing the 127.5 mains and euro needles. The mixture screw plugs were already removed, but the rest of the carb internals had all stock jetting.
I just don't know what size drill bit to use on the slide holes. The original RavenRider write up says to use a "#32 drill bit (2.7mm)" but #32 is actually 2.95mm which is quite a lot bigger than the existing slide holes.
