Carb Rebuild Kit
spyd3rm4n
Aug 21, 2013
183
city of angels
I need to remove and clean my carbs, and want to replace the bowl gaskets, float needle o-ring, needle valve o-ring, and jet holder o-ring at a minimum. Ordering OEM parts is expensive, but there are several kits available. I tried an eBay kit a few years ago and had to return it since the float needles were the wrong length.
Anyone have any experience with the All Balls kit? There's a Dale Walker holeshot carb kit too that looks similar but it's $80 more.
Im a huge fan of everything all balls but can only comment on their bearing side of things. I am a few weeks from buying a bunch of seal kits/carb kit from them and am not thinking twice about it. IMO they are a little overpriced, but everything is right now.
Ended up buying the All Balls kit. Looks to be decent. I'll find out in a week or so how it all works out. I read one review saying the bowl gaskets were too big. I ran into this issue before when I got carb cleaner on the gaskets - they swelled and wouldn't fit. Had to let them dry out for a few hours and shrink back to their normal size.
I took a chance on a $20 eBay carb kit about 3 years ago for my silver Gen I and it ended up not working. The float needle assemblies were the incorrect length and float needle holder tubes were made of a really cheap looking silver metal, not brass like the OEM ones. I ended up reusing the original float needles and just replaced the holder o-ring for the second time in 10 years.
Yeah the ebay stuff is hit and miss and sometimes outright wrong all together.
So far so good, I just have to bolt the float bowls back on and put the top caps back on.
The All Balls kit comes with a ton of o-rings, screws, needles, washers, jets, float needles, and float needle holders. All seem good quality but not everything is marked the same as the original Mikuni parts. For example only the main jets have sizes marked and they're exactly the same as the stock sizes, staggered 130 and 132.5.
I didn't use any of the included jets. The tips of the mixture screws looked thinner than my stock screws so I didn't use them either. The float needles and needles holder are good and I definitely needed those.
Overall it seems like a good kit. If I would have sourced the bowl gaskets, misc o-rings, and float needle assemblies separately I probably would have paid the same ($100). I'm just glad it came with new screws for everything. Most of my existing screws were reusable except the threads on the screws that hold the float bowl pins down got mangled. Good news is the replacement screws fit fine. The real test now is if the bike starts and runs.
I am following the RavenRider jetting, since that worked so well on my Silver bike, sourcing the 127.5 mains and euro needles. The mixture screw plugs were already removed, but the rest of the carb internals had all stock jetting.
I just don't know what size drill bit to use on the slide holes. The original RavenRider write up says to use a "#32 drill bit (2.7mm)" but #32 is actually 2.95mm which is quite a lot bigger than the existing slide holes.
Im in giddy phase after doing a order from them on Thursday. There are tons of fake carb parts out there now so good call on not using those jets.
Im looking at a drill size cheat sheet, and a 32 drill is .116 dia. It makes no mention of 2.95 even though it maths that way. 2.7mm is .106.
Good to know the All Balls kits are an alternative.
The last few carbs I've done with McMaster -Carr O-rings. Good quality o-rings but you end up with a lot of extras after you buy bags of 25.
Mine's set up with Ravenrider tune, but I'm pretty sure I'm not using Euro needles just what ever number of washers (total thickness) he recommends. I think the Euro needles are grooved with a retainer clip to eliminate the washer stack. If you can't find the Euro needles that's an alternative.
Hope the carb work solves your problem.
Got her back up and running. The All Balls kit is good for the gaskets, o-rings, and float needles. That stuff would have cost me more than $100 so overall not a bad deal. As I mentioned above I didn't use their mixture screws since the tips were smaller. The included pilot jets were also not an exact match; they had 15 stamped on the side which is the same size as the OEM jets, however they weren't the exact same length and the threads didn't line up. I was too busy to take pictures.
I also ended up not drilling out the slide holes, didn't want to mess with it. My silver Gen I doesn't have them drilled out and I'm happy with the throttle response.
So how’s the all balls kit holding up?
I’m researching what to do for mine. I got an 02 fz1 cheap. But she needs love. As for kits, I don’t want to do any drilling.
The holeshot kit looks good. But confusing since not sure if it comes with all the o rings and gasket.
Dynojet? Ivan’s? All balls? Ravens?
I’m in Ontario Canada. It ain’t cheap here. Just want the best for the bike. It doesn’t need more power lol so I don’t need a carb kit to increase power. Just smooth proper throttle response.
So far so good! I'm with you on the not wanting to drill idea... even though Ivan's kit is proven so even if you do drill there's no need to ever go back. I did the RavenRider jetting on two FZ1s so far and it is cheap, easy to do, and works so well I have no need to try anything else.
The All Balls kit I used was just the rebuild kit and so far so good, I'm happy. I ended up using the float needle holders and o-rings, float needles, float bowl gaskets, main jet o-rings, and carb cover o-rings. There were several extra parts such as main jets, pilot jets, needles, and o-rings for the fuel rail between carbs which I didn't use.
Holeshot offers a carb rebuild kit and a jet kit, two different things. I'm sure they're great but I saved some $$$ with the all balls rebuild kit and sourcing my own needles and main jets for the jetting modifications.
Just be carefull with jets now a days, There are tons of knockoffs selling jets that are not the right size. Im about to spend $175 for 8 jets cause i know they are right.
I emailed Holeshot days ago and haven't heard back from anyone, so All Balls will have to do for now lol
You did read on Dale's site about his schedule, right ?
"Updated E-Mail Policy...​
Dear Holeshot customer's, I am now answering emails only on W & TH, so please call the shop if you have tuning or technical questions. E mails have gotten out of control, and I can get up to 400 a day. Dale needs to get his other design work and testing done, so please remember he is only one guy. Please try to make your questions short or he just cant keep up. He does his best to take care of each and every one of our Holeshot customer's by returning phone calls and e mails. If you do not get a response back, this usually means your e-mail was blocked or got kicked back. Please call us if you do not get a response back from Dale. Foreign customers out of the USA are best to email Dale W & TH with questions or price requests, but please give him a few days to respond back."
Wellllll, now i did. haha. Makes sense. They should have that note in the Contact Us section, would make more sense. Thanks for letting me know
This is why I didn't use any of the jets in the All Balls carb rebuild kit. I'm sure they were fine but considering the effort to remove carbs, I wanted genuine Mikuni jets.
Sudco is the way to go, they stock everything. Bonus for me is that they're a very short drive away so I can get them same day!
Sadly, Sudco is closed and out of business effective end of May.
I've used Jets R Us for the genuine jets and such.
Some back story on Sudco from Jeff Saunders owner of Z1 Enterprises on the KZ Riders site
"When the Tsunami hit Japan a few years back, it crippled both Keihin and Mikuni. Many of their manufacturers were in the region that was badly hit. This included their slide manufacturer. Keihin chose to discontinue many of the older carb sets rather than reinvest in new tooling- dropping CR29's and other good selling parts. Even to this day Keihin struggles - and that certainly contributed to some of Sudco's woes. Vesrah gaskets have also been problematic. Vesrah's main gasket manufacturer stopped making gaskets for the longest time - and Sudco used to sell a lot of Vesrah gasket sets.
There are other factors involved - including the crazy cost of running a business in California.
It is sad to see them close their doors."
All i got to say is, i hope jets r us has a strong business plan and employees. They may need to get diversified like factory pro to survive.
