CBR6RRRider
Looks good! How does it feel?
Problem with those is that you can't change the fork preload easily now. How much are they lowered now?
Are those just press-fit to the forks? Thus the lower triple clamps the fork and the upper clamps the extension? Looks like it is very effective! CrazyBiker, adjustments simply mean longer tools.
Once you have you fork height set, you can trim the adapters to be only a few(5) mm above thetop clamp, OR attach clipons.
If you can easily take of those extensions then fine otherwise servicing could be a PITA in the future.
Gonna get them trimmed so they are exactly as you suggest. I just need to find someone who can do that.
If they could be taken off as easily as you suggest, the design would not be as stable as it is. Yes, servicing will be a PITA. Forks were serviced prior to install so that's a worry a few more miles down the road.
I just got back from a short ride. I really like the feel of the bike better with the extensions. The shorter front felt a little twitchy before but now it feels more FZ1 like.
I've got that very same mallet. My father bought it in the 1970's some time...
So the extensions are required so you can use your stock top triple?
How do the extensions press into/onto the folk legs?
BTW...I love projects like this! :shoot:
