Hellgate
Oh brother...
Show us the #$@%%&$ bike! :looseit:
Well it may not look to close now but it really is close to being done. Here is a shot from tonight.
Longer front upper brake line will be picked up tomorrow after work.
I have to say that this bike has such eye appealing style for a 250. If they would lose the flame job and go with either a solid color or a two tone, it would boost sales. I forgot to ask you if the flames were decals and also if they were "cleared" over?
Coming along great! Nice job Brad!
Question... will you have to do something with the mirrors now too? Looks like the higher bars are now directly behind them?
Are you sure those are clearcoated decals? I was told that on the plastics, they cannot clearcoat over decals because the flex will pop the clearcoat off the top of a decal? I thought the FZ1 decals were clearcoated but it turned out to be a clever edge to the decals that appeared as a clearcoating.![]()
So, I now plan to get rid of the stock T connection and run a line down the right fork to the right brake caliper and then do a double banjo over to the left. The good news is that my original upper line is the perfect length to jump over right to left.
Started her up this after noon for he first time in 2 months. I have fuel leaking all over the place from the carbs. I have no idea why as I never touched the carbs.
Unless I hooked the fuel lines up wrong. I cannot find anywhere that would show me which hose goes to what. You have to disconnect about 4 lines on this gas tank. Ridiculous! I should have taken photos.
Also have a lot of slack in the throttle cable. Too much for the adjuster. There are three different attachment points inside the throttle. I need to open it back up and place it in the farthest slot back.
I will not have photos with the fairing back on today but should have photos soon with the tank and bars all setup.
Just give the bottom of the carbs a couple of taps on the float bowl with the end of a screwdriver. You may have one float stuck. No biggie. Sometimes just a couple of taps will free it up.
I'm sure the leak is not something major.
Today I started it up and no leaks. I have no idea what it was but I am happy.
I have cheated! I took the bike in to the shop today to have them finish the last few things that need to be done. Front brake lines, lower front and change the fork oil from 5wt to 7wt.
Will be picking it up Next weekend.
It is just to damn hot out to work on the bike in my garage and I just got a big raise so I figure I would let someone else finish it up.
Congrats on the big raise!!! :Rockon: That is awesome Brad!
