B
Buildercher
Guest
Checkout the kink in the factory fuel line. Yamaha used a cheap nylon fuel line on the Gen2. Cost me $6.40 to replace with a 6mm (inside diameter) rubber fuel line rated @ 400 psi & 2 hose clamps. If you have a Gen2 pop up your tank and check it asap.
