That's interesting... how does that work that he provides all this?
The flash includes:
Ignition timing changes including removing the timing restrictions in the lower gears
Secondary throttle plate adjustments, for improved mid range power ( I do not recommend using aftermarket smaller throttle plates or removing them with the flash)
Fueling changes to match your modifications (no piggy back fuel controller needed)
Fan temp modification
Speedometer correction
Disable injector decal cut, disable AIS, disable EXUP
Rev limiter adjustment
Your bike will be smoother. more powerful and more fun to ride.
Lifetime reflashes are included in original purchase to original purchaser. Shipping fees still apply."
EXUP and AIS needs to be done manually... so I guess a bunch of other things there?
Anyway, you just mailed in a computer from inside the bike?
