ilawrence111
Bought new coil thing and flywheel for obvious reasons. I pulled out my stator and the flywheel is connected to the coil and won’t let go. It makes a grinding sound when I turn it. I can’t pull or pry it off from the coil and case cover. I’ve seen some threads referring to a special tool that can pull it off but idk how it works. Anyone have a video or pictures or any links on how to use it? Do the three torx bolts need to be removed? Also, are there any other tricks to removing the flywheel from the stator with readily available everyday tools? Any help is greatly appreciated.
