Dustin
Moderator
2017 Kawasaki Z125 Pro - Pocket-Sized Fun
Engine: 4-stroke, 1 cylinder, SOHC, 2-valve, air-cooled
Displacement: 125cc
Bore x stroke: 56.0 x 50.6mm
Compression ratio: 9.8:1
Fuel system: DFI® with 24mm throttle body
Ignition: TCBI with electronic advance
Transmission: 4-speed, return shift
Final drive: Sealed chain
Rake / trail: 26.0 degrees / 2.7 in.
Front tire: 100/90-12
Rear tire: 120/70-12
Wheelbase: 46.3 in.
Front suspension / wheel travel: Inverted telescopic fork/3.9 in
Rear suspension / wheel travel: Swingarm, single shock/4.1 in
Front brakes: Single 200mm petal-style disc
Rear brakes: Single 184mm petal-style disc
Overall length: 66.9 in
Overall width: 29.5 in.
Overall height: 39.6 in.
Seat height: 31.7 in.
Curb weight: 224.8 lbs.
Fuel capacity: 2.0 gal.
Color choices: Candy Lime Green & Metallic Graphite Grey
Me likey!
