Swingarm extensions?
Mross52
New Member
Jan 7, 2016
North carolina
I'm looking to stretch my 06 fz1, I saw here before I joined that someone mentioned using 04-06 r1 extionsions an they would work. I ordered a set of extensions from FTD customs and they do not fit because the ovals on the extensions don't fit in the slot on my swingarm. Someone please help I'm stuck here now and I really would like to know what to do.
Thats odd. Mine were off a 04 r1. I do think they changed the r1 swingarm some in 06 but most parts say 04-06 when you buy them. When we did mine I took the parts off my buddys 04 so all the parts I ordered were for a 2004 r1. I still lurk around, this forum has a great bunch of people
I would call them. If they sell them under 04-06 one would think they are all the same, but it never hurts to ask. If they are all the same for the three years maybe the ones you received are for something else all together.
04-06 are the same i went down this route with strecheds advice
i used the r1 extensions r1 hanger from 05
longer brake line and 154 links
i also used a 2mm shim this is because i used r1 wheels
note for the rear brake to work you will need to grind of the hanger guides off for clearance
Swingarm extension and hanger?
Hey, I'm new to the site and I also just got my 06 fz1 about 6 months ago. I have read in the above posts about the R1 swingarm extensions fitting on the 06. You said you used R1 hanger. What is this hanger you are referring to?
Swingarm extension
Hey guys I'm new to the site and also a proud owner of a 06 fz1. I just got it 6 months ago and it is all stock except for stainless steel brake lines and gyt-r pipe. I had a couple of questions about the above posts. I have read that the r1 swingarm extension will fit. But it is also mentioned that you use a different hanger. What is this hanger that everyone is referring to?
